Time for Tierods and other stuff <--Parts info included
Old Jan 25, 2014 | 08:55 AM
rtmtrrdr's Avatar
rtmtrrdr
I wasn't implying that you didn't know how to do it lol. I'm just saying that I'd hate for you to tear it apart,put it back together and realize that you should've done the other things also. Then tear it apart again. That's what happened to me! . As for the not getting the alignment, it can be done. I tried it. I got the drivers side right on,But got the pass side off by 2 degrees. It wasn't much, but it was enough to notice lol! Hope you have better luck than I did
Old Jan 25, 2014 | 09:59 AM
dirtydog's Avatar
dirtydog
Moderate User
@rtm I got ya man. no worries. There really isnt much more to tear apart if I have to go back in for the BJ's other than knocking the tierod back off and thats a piece of cake!
I just dont want to spend anymore money. As it is, I ONLY need the one outer tierod.
The seal leak is very very minor and the swaybar bushings...I'm just a freak and most people wouldnt ever change them out.
Old Jan 25, 2014 | 10:08 AM
dirtydog's Avatar
dirtydog
Moderate User
and I just measured my sway bar diameter. It is 32mm. I'm, going to replace the swaybar mount bushings as well to match the end links.
Old Jan 25, 2014 | 06:41 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sounds like fun. Doing my front end was a piece of cake but the again, I dont live up north with salt, sand and snow.
Old Jan 25, 2014 | 08:28 PM
dirtydog's Avatar
dirtydog
Moderate User
I spray my truck off underneath EVERY time it goes on the street in a storm. There's a spray wash at the end of my street.
I drive my Buick for the most part as I put 4 snows on it for the winter. It does exceptional. The truck only goes out in the middle of a storm if need be.
This is a pic of the back and frame rail. The front looks just the same!
Attached Thumbnails Time for Tierods and other stuff &lt;--Parts info included-th_p2040118.jpg   Time for Tierods and other stuff &lt;--Parts info included-th_p2040115.jpg
Old Jan 25, 2014 | 09:54 PM
08HEMI1500's Avatar
08HEMI1500
Good to know on the prices. I might need to do this myself soon as I'm having some serious rattle noise and it's either coming from the shock mounts or the tie rods. Hopefully I won't need to do BJs either since I don't have the tools to do those being up in college.
Old Jan 31, 2014 | 04:59 PM
dirtydog's Avatar
dirtydog
Moderate User
So I just swapped out my pass side outer tie rod for now. Took 20min total.
I peeled the boot off the tie rod which was in good shape, no dry rot or rips. Do they even put grease in these things? There was barely anything in there. There is significant up/down and side/side play. The threaded part wont even stay straight up without falling to one side. There's rust in there as well. I suppose I probably could have injected some grease in there but that won't get it up inside the joint area...
Note: I did not wipe it down at all.
The driver side inner rod has some play but it'll be fine until warmer weather because i rarely drive the truck anyways.
I'm going to either replace the outer seals or do a whole rack rebuild. Haven't decided yet.
Attached Thumbnails Time for Tierods and other stuff &lt;--Parts info included-th_20140131_164959_zps8de0ede0.jpg
