3.7 motor knock
Old Jan 25, 2014 | 10:23 PM
Deerhunter90's Avatar
Deerhunter90
Default 3.7 motor knock
Yesterday after our good cold day (28-30 degrees) I noticed my truck starting to knock. I did take a video and will post it as soon as I learn how, what are my chances this is an easy fix?
Old Jan 25, 2014 | 10:41 PM
Deerhunter90
Old Jan 25, 2014 | 11:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
Take the fan belt off and inspect the water pump.
Old Jan 26, 2014 | 09:05 AM
Deerhunter90
Anything in particular I should be looking for
Old Jan 26, 2014 | 07:06 PM
master tech
Is the pulley loose? Because I had the same noise from a 3.6 pentastar engine in a 2012 minivan. The pulley for the water pump had broken.
Old Jan 26, 2014 | 10:27 PM
Deerhunter90
It seemed ok I do however have a new pump and fan clutch for it I'll put them on and hope for the best. Most everyone who hears it says it's a rod knocking.
Old Jan 26, 2014 | 11:11 PM
master tech
Did you start the engine without the fan belt on the engine? Does it still make the knocking sound?
Old Jan 27, 2014 | 08:13 PM
Deerhunter90
Ended being the water pump, the pulley was almost completly seperated from the actual water pump. Runs like a top
Old Jan 27, 2014 | 09:08 PM
66three83's Avatar
66three83
Great news! Thanks for the update, it could help others.
Old Jan 27, 2014 | 11:40 PM
master tech
Good Job! We'll make you a dodge tech.
