Water pump leak?
Here is my question? My 02' 1500 5.9 is throwing a malfunctioning thermostat code. But this would be the 3rd one that I have gone through this year. On Jan 1st I replaced the water pump, top and bottom rad hoses, thermostat/seal. Once I had replaced all of those parts my 1st check engine light came off and stayed off until the past week when it came back on saying bad stat again. I have also noticed that it leaks a lot fluid right after I shut it off but it does not always do this. The leak seems to be coming from around the water pump on the right side facing the truck. I does not seem to be the pump to be, seeing that all around it is dry expect off to the side.
