Anyone know what this is?
Old Feb 9, 2014 | 07:26 PM
armophob's Avatar
armophob
Default Anyone know what this is?
I opened the hood and shut it again, when I looked down, I found this on the garage floor near the drivers front of the truck.
Anyone know where is located or what it is supposed to be attached to?
It is made of hard rubber.
Old Feb 9, 2014 | 07:34 PM
p38251's Avatar
p38251
Looks like a bumper for the grill. Open the hood and look on the front side of the radiator support
Old Feb 9, 2014 | 08:05 PM
armophob's Avatar
armophob
I think you are right. Down on the lower sides. I could not find it because I do not have the left or the right now.
Thanks!!
Old Feb 9, 2014 | 09:56 PM
itsUhHemi's Avatar
itsUhHemi
Either that or it's the little block that holds your battery down.
Old Feb 9, 2014 | 11:58 PM
armophob's Avatar
armophob
It is funny you would mention that. I finally found the source of the corrosive buildup on my garage floor. While looking for the location of this part I found that the bolt that goes through that rubber piece holding down the battery is thick with corrosion. So much so it is dripping down from the bottom with crystals.
I am mystified how this bolt would pick up the properties of the battery terminals when it is separated with that rubber piece in between.
Old Feb 10, 2014 | 03:14 AM
abarmby's Avatar
abarmby
Clean all that up and find the source of the leak.
The ABS module is underneath the battery try I believe and stuff like this causes the ABS module failures we here a lot about = expensive!!
Al.
Old Feb 10, 2014 | 08:51 PM
icywhite's Avatar
icywhite
its the hood grill bumper
Old Feb 11, 2014 | 05:09 AM
armophob's Avatar
armophob
Al.
I will follow that up
Old Feb 11, 2014 | 05:13 AM
armophob's Avatar
armophob
Moderators can close this thread
FYI the part is DODGE OEM 55077387AA Grille-Bumper
