3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a 03 1500 4x4. i wanting to do a sas with a gm 14 bolt & dana 60. wondering what leaf springs i shoud use for the rear if im wanting to shoot for around a 12inch lift. i would like not to use blocks either.
You could literally use stock if you wanted. IMO, I would try and run some 2500HD rear leafs...as they will be slightly higher rate and give you the clearance you need.
