BBK 4009 shorties fit 4x4?
I called BBK about the fit on my 05 2500 4x4. They told me they won't fit. Said the engine is slightly off set to the right to clear the front differential and doesn't leave enough clearance between the engine and frame.
Hope this helps.
Calvin
Hope this helps.
Calvin
I sure will, I will go so far as to do minor fitting if required. There is nothing affordable for my truck for headers. Worst case I will put the new motor in with stock manifolds for now. The previous motor ventilated the block with a piston
Trending Topics
I asked BBK support what specifically it may touch or interfere with. I also found this which is interesting as it says fits 2500:
http://www.summitracing.com/parts/bb...model/ram-2500
