frt hub nut size?
frt hub nut size?
I need to replace my lt frt hub bearing assembly and want to have all the tools needed in hand before I start . I need to now what size socket I need for the big nut on my 2006 ram 1500 4 w/d and also the 3 smaller nut that hold the assembly on the back side of the assembly.
THANKS
TOM
THANKS
TOM
Hey, I just did this myself It should be a 35 MM axle nut, and 18MM hub bolts. I don't recall the size of the caliper mounting bracket, but I think it was 3/4". Make sure you have on hand new bolts for the hub in case they get damaged. I summed up my install here:
https://dodgeforum.com/forum/3153650-post15.html
BUGGSY;
thanks ever so much for the feed back and the really good summery of your change procedure. That was about the best explanation of a process that I have ever read. simple and precise. Just was wondering what year truck you were working on, so as not to get apples and organges mixed up.
THANKS
TOM
THANKS
TOM
Axle nuts are kind of forgiving on the socket size. The book says a 35mm, and that is what I used. The axle socket kits that you can buy/rent at auto stores are often just the even sizes, so that's what people use. I rented a set last summer to do the hub on my sister's car and just made do with a socket slightly too big. I think you'd actually be fine with a 36mm, but I'm positive I used a 35mm. This is what I bought:
http://shop.advanceautoparts.com/p/a...841/10074000-P
Trending Topics
