trouble code p 330
Old Oct 16, 2005 | 10:15 PM
skoll's Avatar
skoll
Default trouble code p 330
does anyone know what p330 means on a 05 1500
Old Oct 16, 2005 | 10:26 PM
osteodoc08's Avatar
osteodoc08
Default RE: trouble code p 330
Try this link. It will bring up another page in PDF format.
It says it is a knock sensor, bank 2.
How many miles and what mileage? Also, what service work has been done?
Old Oct 17, 2005 | 09:33 AM
hemifever's Avatar
hemifever
SPONSOR
Which side is bank 2? Passenger?
Old Oct 17, 2005 | 04:03 PM
osteodoc08's Avatar
osteodoc08
It's been a while but I think that Bank 1 is on the #1 cylinder side (normally driver's side) and Bank 2 is on the #2 cylinder side (normally passenger's side)
Skoll, got your PM. If you don't want to take it to the stealership you can reset the computer and see if it happens again. If you do that, be sure to make sure all of your plug boots are on securely, although I doubt it was your problem. If the engine is running fine other wise, that is what I'd do, just reset the computer and see if it happens again. Also make sure you have good gas.
