Just replaced right rear axle seal
Old May 4, 2014 | 11:12 PM
Willy McNasty's Avatar
Willy McNasty
Unhappy Just replaced right rear axle seal
Yesterday finished up replacing both rear axle seal as the right was leaking pretty badly. Drove maybe a total of 50 miles & it's leaking again. Could it have been leaking from somewhere else to begin with? When I got Italy apart there was gear oil everywhere so I didn't think about the possibility of it leaking from another place. Thanks!
Old May 5, 2014 | 05:10 PM
Willy McNasty
I'm sure anyone with more experience would have caught this...I did notice some wear on the bearing. After consulting someone more experienced than I I've come to find out the axle is scarred from the bearing where it has detèriorated . A new axle shaft & bearing should fix me up.
Old May 5, 2014 | 06:41 PM
rought's Avatar
rought
are you sure you didnt put them on backwards? Its easy to do..I replaced mine at 190,000 and my axels were fine, no leaks.
Old May 5, 2014 | 07:42 PM
Willy McNasty
Haha I'm not quite that Ameritex but that is easy to do for sure. The seals were installed correctly. The bearing & axle are worn so they don't marry up correctly & have too much play so there is not a good seal between them @ the seal. There were metal shavings at the seal.
Old May 10, 2014 | 12:35 AM
timekop's Avatar
timekop
As cheap as the bearings are, a guy might as well replace both seal and bearings. Kinda hard to believe your axle would have been damaged so badly. Hope you got it fixed.
Old May 10, 2014 | 09:23 AM
Willy McNasty
Yes, it's been leak free for a few hundred miles now. New axle bearing & seal. I anyone is interested I can post pictures of the old axle.
Old May 11, 2014 | 07:32 AM
abarmby's Avatar
abarmby
Not giving you work to do but, could you post up those pics of the damaged axle.
Many thanks.
Al.
Old May 11, 2014 | 04:39 PM
dirtydog's Avatar
dirtydog
Moderate User
ANY time you replace the seals AND/OR bearings, you should use emery paper on the axle shafts to remove any shiny areas, ridges and corrosion on the outer edge that the seal rides on. Pitting is the biggest thing you would look for with wear.
