Left headlight out
I had a headlight fart around for a couple weeks. Would work one time and not the other. Now it is out for about a month and the bulb isn't the problem. I couldn't find anything in the fuse/relay box for headlight/headlamps. Wiring from main harness behind fuse box to the plug and the plug look fine. Any ideas what the problem could be? I haven't checked for current.
many 2002 to 2006 has a electronic fuse box... or the TIPM...
corrosion gets inside it.. and you end up with several intermittent.. electric problems.
starts with head light or starts with tail/brake lights.. and progresses into other circuits.
I got lucky so far. it only attacked the trailer light circuits.. and I wired around it using an aftermarket trailer light system.
BUT do not go MAD and replace the "BOX" ... proper wire/electric TESTING is needed... could be a bad bulb or socket ...TEST it.
I also got me a Plastic Showercap for the women who don't wanna get wet under the shower and fitted it over the box after I installed it. I also placed a rag on top to make sure, no water or moister runs into the box.
checked it couple of times- after car wash and rain (more car wash than rain, because we do not have that event too often here) and seems like it's ok.
the box is really on a stupid location. should be inside under the dash- there is room enough for it.
good luck.
