Good blend doors and motors but AC still hot on driver side
So I have pulled my dash board and checked all blend doors and motors that run the blend doors and everything is good. No leaks in system but the driver side of the AC is not working. The passenger is working great and everything blows cold everywhere else. Just driver side is bad. It blows just fine just not cold. Heater works just fine on all vents. Do you think a flush of the system would be a good idea and fix everything?? IDEAS????
Yes the heater does blow out of all vents. And no I don't have a dual zone control system. The air doesn't get cold on recirculate. I always have it on there and it doesn't work. I did make sure all door motors were working. I removed all the motors and tested them on and off the doers themselves. Any more ideas. Thanks for the help.
I understand the motors tested good but did you watch all the doors move when changing different selections?
The doors controls flow. That's the only thing that control flow. One of your doors isn't moving as/when it should
