Transmission Temperature sender
Old 05-26-2014, 12:45 PM
Lee Carey's Avatar
Lee Carey
Lee Carey is offline
Default Transmission Temperature sender
I purchased this truck with a temperature gauge already installed, I am seeing high temperatures on this gauge with the truck performing minimal work.I was wondering if this is the best port to pull and accurate temperature from this transmission. See Photos. On a side note what model is this transmission?
Old 05-26-2014, 09:23 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Define high temps so we can tell you if it's normal or not.
Old 05-26-2014, 10:10 PM
Lee Carey's Avatar
Lee Carey
Default High Temperature
Approaching 240 degrees pulling slight grade with 30ft fifth wheel, 65MPH road. In town it will climb over 200 during
normal driving.
Old 05-26-2014, 10:11 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Very normal. Nothing wrong
Old 05-28-2014, 06:23 PM
Lee Carey's Avatar
Lee Carey
thank you for the answer, can you tell me if the sending unit is in the best location?
Old 05-28-2014, 06:57 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
IDK if this wil help since there are no pics but it might
https://dodgeforum.com/forum/3rd-gen...gauge-diy.html
Old 05-29-2014, 10:36 AM
Arctodus's Avatar
Arctodus
Arctodus is offline
normal driving.
That seems a little on the high side. Weed is pretty knowledgable but over 200 with normal driving? I can see the 240 pulling a 30'er.
Old 05-29-2014, 07:20 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
200 to 240 is average. Ambient temps, fluid conditions, fluid level, driving style, trans filer all can affect fluid temps.
Quick Reply: Transmission Temperature sender
