Pulling codes(Check Engine Light)
Old Jun 8, 2014 | 05:17 PM
riffle.riley's Avatar
riffle.riley
Default Pulling codes(Check Engine Light)
When I pull codes for my truck most of them are just small evaporation leaks is there a easy cheap way to fix or am I just going to have to stare at my check engine light while I drive....HELP PLEASE!!!!!!!!!!!!
Old Jun 8, 2014 | 06:17 PM
p38251's Avatar
p38251
There could be several leaks, in many places. I would have a smoke check done. Way easier to find leaks.
Old Jun 8, 2014 | 07:31 PM
HemiRam1566's Avatar
HemiRam1566
yea smoke test is the way to go, also find out if its a gross evap leake or a small evap leak, gros evap leake could be somthing very noticable like a crack in the charcole canister(been there done that)
also have a good look at the seal on your gas cap, remove it and flip the seal, could be somthing simple as that
connor
Old Jun 8, 2014 | 10:06 PM
riffle.riley
How much does a smoke test usually cost???
Old Jun 9, 2014 | 07:59 AM
HemiRam1566
i would imagine a hours labour
Old Jun 9, 2014 | 10:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Post your codes
Old Jun 9, 2014 | 07:10 PM
riffle.riley
I will so we cleared them I have to wait till my light comes back on I personal message you when they come back on weedahoe
Old Jun 10, 2014 | 06:32 PM
gunbunny2bg4u's Avatar
gunbunny2bg4u
replace the gas cap. is like a po40 or some thing like that. small evap leak.
