Power steering problem
Old Jun 11, 2014 | 09:20 PM
Kris Heiselberg's Avatar
Kris Heiselberg
I'm having a hard time finding a pump with the pulley installed. The one I linked to on eBay, actually didn't have the pulley wheel installed, although the picture shows otherwise. Any recommendations on where to buy either a remanufactured or used pump with the pulley wheel on it?
Old Jun 14, 2014 | 10:34 AM
gunbunny2bg4u's Avatar
gunbunny2bg4u
I got the remote style not the ford style pump. I bought a reman with out the reservoir. I just reused it. and not a rebuild pump and it was less than a100 bucks
Old Jun 14, 2014 | 10:36 AM
gunbunny2bg4u
I just rented a pulley puller and installer from auto zone. its a kit that works well. and you get the rent money back when your done with it. its ez
Old Jul 17, 2014 | 01:19 PM
Willy McNasty's Avatar
Willy McNasty
Question
Pros & cons of continuing to drive with a leaking pump? Will refilling the reservoir be okay until replacement? Or can damaged be caused to other parts?
Old Jul 17, 2014 | 02:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As long as you keep ATF4 in it you will be fine
Old Jul 17, 2014 | 07:44 PM
CopenghagenHemi22's Avatar
CopenghagenHemi22
I bought pump and solved the problem. if you are doing it yourself i would get one with pulley already on. If not if you dont have a pulley press, rent one from autozone. It is not an easy task switching the pulley over, but manageable. Good luck, i just did this recently so if you have any questions message me.
Old Jul 21, 2014 | 09:43 PM
Kris Heiselberg
Update on my pump, bought a used one off of eBay with the pulley wheel and reservoir and sent it to my freight forwarding address in Florida. Got it a week after here in Greenland and replaced the old one with it. Got help from two of my friends, which speeded up the process. Got it done in about 2 hours. Problem solved, just like Weedahoe said. If details are needed, just ask, but it's a pretty straight forward job. 3 bolts to get the pump off and just screw off the 2 hoses. Have some kind of a pan to catch the oil, as it gets quite messy when draining the system. Picked up 5 liters of ATF4, as I was unsure how much the entire system could have, but turns out you just need about 1 liter for the whole system. But having the pulley wheel on the replacement pump, saved me alot of time and tools.
Old Jul 22, 2014 | 11:04 AM
CopenghagenHemi22
Thanks for the update, yeah thats exactly how mine went. Except I bought one without the pulley since it was quite a bit cheaper. Rented tool from autozone, got my $40 back when I returned so it saved me some money. But with 35's my truck was next to impossible to drive in parking lots, sure am glad I fixed this.
