03 Dodge Ram 1500 5.9L engine OVERHEATING
I have an 03 Dodge Ram 1500 Quad Cab 5.9L engine. It has 190,000 miles on it.
Recently I have been having overheating issues. All of the years I've owned it (original owner) I've never experienced this. I have, however, replaced the water pump because it siezed on me. I have flushed the radiator and heating core. I continually (everyday) I have to add water.
Oil is not milky and I cannot see indications of a leak. It does smell like hot water though. I recently noticed that the A/C condenser fan does not engage (I have heard the distinct sound before) but now I don't hear it. Before I purchase parts, is this a problem with overheating as I described or are there other items I need to look at as well
I look forward to responses
David G.
David G.
A coolant system is fairly simple.
Thermostat
Radiator/hoses
heater core/hoses
water pump
head gaskets
Low coolant
That's all you have. If both upper and lower hoses are hot and stiff, you have pressure and circulation. If not, the pump might not be circulating or something might be blocking it (hoses, rad, stat). If all of that is good, then the head gaskets might be suspect and a pressure check needs to be done
Thermostat
Radiator/hoses
heater core/hoses
water pump
head gaskets
Low coolant
Thermostat
Radiator/hoses
heater core/hoses
water pump
head gaskets
Low coolant
Thermostat
Radiator/hoses
heater core/hoses
water pump
head gaskets
Low coolant
