Front end rebuild torque specs please
Old 07-11-2014, 09:20 AM
subzero32's Avatar
subzero32
subzero32 is offline
Default Front end rebuild torque specs please
I am in the process of overhauling my front end on my 04' Ram, 4.7 RWD and wanted to know some torque specs so I do it right the first time. I need 1) brake caliper 2) brake caliper bracket 3) upper control arm 4) lower ball joint 5) tie rod end 6) sway bar bushing bracket 7) sway bar end link 8) wheel lug nuts (100 ftlbs? or more?). The lower ball joint was a pain to remove, I ended up just using my mini sledge to beat it out then press it in with an autozone press kit. I'm using Moog parts with zerk fittings so it should be better.
Old 07-11-2014, 03:05 PM
thunderhawk09's Avatar
thunderhawk09
thunderhawk09 is offline
1 Brake Calipers 24 ft Lbs
2 Brake Caliper Bracket 130 ft lbs
3 Upper Control Arm/arm to frame 97 ft Lbs
Ball joint To Steering knuckle 60 Ft Lbs
4 Lower Control Arm/ arm to frame pivot bolts 150 Ft Lbs
Ball joint to steering Knuckle 60 Ft Lbs
5 tie Rod End Adjuster Clamp Bolts 45 Ft Lbs
Tie rod ends
Step 1 45 Ft Lbs
Step2 90 Degrees More
6 Stablilizer Bar
Clamps To Frame Rail 45 Ft Lbs
7 Link mounting nuts
Upper 27 Ft Lbs
Lower 75Ft bs
8 Wheel Lug Nuts 135 Ft Lbs
Anymore help let me know got manual
Old 07-11-2014, 04:46 PM
cd36c's Avatar
cd36c
cd36c is offline
Correct me if I'm wrong, but I believe the ball joints have a +90° turn as well, don't they?
Old 07-12-2014, 04:48 AM
thunderhawk09
No they don't show too In manual just the tie rod ends
Quick Reply: Front end rebuild torque specs please
