how to change blown bubls where ac/heater and temp knobs are?
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
There are a couple of threads on this but I replaced mine with LED's. Don't remember the number for the LED's but a Google search or site search should bring it up.
Super bright led theres there sizes make sure to get neo4's and get the ones at top of list they have a wider beam angle which will eliminate hot spots when shopping for dash lights look for the led's that has SMD Led's they have the best beam spread The NEO4 That's 2.29 each they are SMD
If you choose to do your dash lights with led The bulbs are B8.5
NOTE: If your Just looking to replace them With standard bulb The # is PC118/PC119
im just going to put the regular bulbs in.i still cant find the post of how to change them. thanks for posting the number of the regular bulbs.
One place I found them bulbs was ebay as for changing them they are simple to change out just 1/4 turn Counter clockwise and pull out reverse to install
I believe he is asking how to disassemble the dash to remove the proper control unit in order to gain access to the bulb(s) in question.
