steering front end noise
Old Aug 6, 2014 | 07:06 PM
tav's Avatar
tav
Default steering front end noise
This just started to happen.... turning steering wheel back and forth the while sitting still
I hear a clunking noise.could. it be. The coupling on the steering shaft.
Old Aug 7, 2014 | 11:30 AM
TejasMtnBiker's Avatar
TejasMtnBiker
ball joints upper & lower and them outer tie rods, unless this is all brand new then check the control arm bushings
Old Aug 8, 2014 | 08:14 AM
tav's Avatar
tav
Maybe not protocol but I put some wd40 on that steering
coupling and it worked.
Old Aug 8, 2014 | 09:21 AM
Buggsy's Avatar
Buggsy
Sounds like it was binding. If WD-40 helped, you can try to clean it off (soap and water with a brush or maybe brake parts cleaner) and grease it with something longer lasting like Lithium spray grease.
