'08 1500 lower ball joint replace
Okay guys here I go again. Getting ready to replace the lower ball joint on this truck I bought. '08 1500 crew cab, Saw a couple of videos on YouTube. They show drilling/cutting out the rivets and replacing the whole joint assembly not just the ball joint. Looking at the oem one on the truck, it appears the ball joint was flanged slightly on the top. Will the press tool get it out or do I need to remove the lower arm and carry it to a machine shop?
on
Just did my prior truck ('04) about six months ago and they were pressed. Bought Moog lowers WITH A ZIRC.
Also, when you go to do the uppers, unless they changed between '04 & '08, you'll have to do the entire control arm. I also went with Moog which not only have a zirc, but they can be removed without having to do the entire control arm in the future...
My 05 was pressed in too, I think GM uses alot of riveted in joints, but Dodge is alot of pressed in, unless the newer ones changed.
To do the lowers on a 4x4 you'll basically need to tear apart the whole suspension, remove the steering knuckle and set the half shaft out of the way. THen you can get access to the ball joint to press it out/in. Put the new ones in the freezer and they'll slide in alot easier.
Also, the factory ball joint is peened at the top so you may either need to grind off the indents or tap them with a hammber and chisel so it will slide out easier.
It is really a pretty easy job, just need to take everything apart to get to it, but that is really only 4 bolts (upper BJ, lower BJ, Spindle Nut, TIe Rod End). While you are in there check everything else for play and replace as needed, so you only need to get one alignment.
Appreciate it. Just bought this truck a week or so ago. It appears all the owners did was change the tires, oil & filters, so says the car fax. oh, and wiper blades once and all this was dealer service. So i've already bought all the ball joints, hub bearing assys, brake rotors and pads ( all 4), tie rod ends, shocks and radiator, water pump and t stat. Will have to do the pinion seal too but focusing on the safety/survivabilty and preserving the 164K engine for now.
