2003 ram 1500 3.7 coolant leaking from overflow
Old Oct 28, 2014 | 08:06 AM
  #21
Deerhunter90's Avatar
Deerhunter90
Originally Posted by Mlj1111
Why bother? Can probably get a motor with less miles installed for less then the cost of another vehicle.
Or replace the head gaskets yourself. Realizing it has high miles, I would go with option one. ( heads may be warped or whatever. )
Cost of a good used motor 800 to 1500, cost to have installed 600 minimum around here by a reputable mechanic.
I do not think I could buy a vehicle without issues for that low a price.
(unless its some guy selling to support his drug habit if I were lucky )
Mines in shop as we speak $1500 total installed for complete motor out of a rollover with 86000 miles.
Mike
Edit~ I can see that its a 2 door and that would be reason to me anyways to grab a quad cab personally anyways. You would make more parting it out over a trade in at this point anyways if you do not fix it. Looks pretty clean really.
Getting a quad cab is the only reason I won't fix it, it's an exceptionally clean truck but with our next little one due in a few months we need more room. My local dealer offered me $3000 trade in on it last time I was up there and that sounds pretty fair to me. I'll make a decision and update, I'm not in a hurry since I've got a 97 ram with 53,000 miles on it I can use for work .
Old Nov 11, 2014 | 11:35 PM
  #22
Blueball's Avatar
Blueball
Definately head gasket. Exactly the same thing happened to me. Overheated it once and blamo .. leaked from overflow ever since. Confirmed hydrocarbons in coolant. Zip tied a plastic bottle to the overflow and that got me by for a while ... had my engine rebuilt at accurate engines in Michigan. Cost me $3k for a long block installed.
I now drive an Ecodiesel. Entirely different beast. Sips fuel .. lots of turbo lag.
Old Nov 12, 2014 | 08:10 AM
  #23
Deerhunter90
The truck has never been close to over heating though, that's why it's hard for me to believe it's a head gasket.
Old Nov 13, 2014 | 04:58 PM
  #24
Prismatic's Avatar
Prismatic
Another idea is air entering the cooling system from somewhere. While recently doing my exhaust manifold bolts I saw on the passenger side a heater line that has a factory coupler installed. This showed very obvious signs of coolant seepage. I replaced the factory spring clamps with screw clamps. That, combined with my new, factory 17lbs radiator cap, has entirely fixed my overflow issue.
Old Nov 13, 2014 | 05:32 PM
  #25
Mlj1111's Avatar
Mlj1111
He already stated that number 6 plug was soaked in antifreeze.
Good idea, but sadly not the case.
Mike
Old Nov 13, 2014 | 05:41 PM
  #26
Prismatic's Avatar
Prismatic
Mike
oh. Well better luck next time!
