3" suspension lift/leveling kit help
Old Nov 16, 2014 | 09:14 PM
Rocking 67's Avatar
Rocking 67
Default 3" suspension lift/leveling kit help
Hi all,
I have a '06 3500 Mega cab 4WD, Cummins and a '98 quad cab 2500 4WD, Cummins with 5spd.
So, it only makes sense, we bought my son a 2005 1500 4WD 4DR. It came with 31" tires, he would like to put a 3" lift/leveling kit. The largest tire he would want would be 33".
I did not have to lift my other trucks, though I did beef up the rear suspension on the '98 and will lift the front on the '06 here soon.
3" lift and leveling, suspension, no body lift.
So, I am open to suggestions for the best complete kit or combo I could get. I have seen a lot, but the cost range is so wide it is not funny. I do not know enough about the products on line to make a good choice. I live in the Central Valley of California, 15 miles from the nearest town and 60 miles from Modesto. I am trying to locate a local company, but so far no luck.
I do not mind buying the kit from one company and matching it to a good set of shocks. I would like to hear about good companies and the ones to avoid.
Any help and direction is appreciated.
Old Nov 17, 2014 | 10:21 PM
TheRECENDEZ1's Avatar
TheRECENDEZ1
I am in the same position 06 5.9 3500 SRW megacab 4x4. Looking for a 3 inch lift kit, not the spacers.
any recommendations?
Old Nov 19, 2014 | 07:44 PM
p38251's Avatar
p38251
Look into rough country. I just received my 2inch front leveling springs for my 12. They have packages with and without shocks. I went with bilstein shocks.
Old Nov 20, 2014 | 08:56 AM
TheRECENDEZ1
Are you running bigger wheels? Also, what exact bilsten shocks did you end up getting?
Did you noticed a height difference after the installation?
Old Nov 21, 2014 | 09:17 PM
p38251's Avatar
p38251
Yes 305/70/17 Nittos. Went with the zero-2.5 inchs of lift shocks. No height difference. Rides much better.
Old Nov 22, 2014 | 05:07 PM
TheRECENDEZ1
Awesome, I'll probably do the same on mine for coil springs. Post some pictures of your truck after the installation if you dont mind.
Old Nov 22, 2014 | 06:53 PM
p38251's Avatar
p38251
Will do
