Engine tapping noise
Old Dec 16, 2014 | 05:18 PM
jacks187's Avatar
jacks187
Default Engine tapping noise
2006 Dodge Ram 2500, Hemi 5.7L, just went over 100,000 Never had the spark plugs changed, oil changed faithfully every 3000 miles since Ive had it. Never any major engine issues except the engine light will come on if the transmission fluid is low.
I know its over due for the sparkplugs but all of a sudden there is this awful tapping noise when I first give it gas going up to about 40mph. sounds like its running with no oil in it but the oil is perfectly on the top of the hashmarks and it has sufficient oil in it. It does it when i give it gas two or three times and when I lay off of it, it stops. Then I can give her all she got and no tapping noise. Any suggestions?
http://cimg7.ibsrv.net/gimg/dodgefor...30376c9b51.jpg
Old Dec 16, 2014 | 06:15 PM
SoBadass's Avatar
SoBadass
Check for exhaust leak. Mine doing same. realized its missing two exhaust bolts
Old Dec 16, 2014 | 09:20 PM
jacks187's Avatar
jacks187
Holy crap, does your make this short brief squeaky noise when it first starts up like a rat or somthin got caught in the belt???
Old Dec 17, 2014 | 07:04 AM
SoBadass's Avatar
SoBadass
Yes is does
Old Dec 17, 2014 | 10:07 AM
jacks187's Avatar
jacks187
Das whas up man........where u stationed?
Old Dec 18, 2014 | 07:13 AM
ssbracing's Avatar
ssbracing
My sons 2010 Hemi is doing the same thing, we think it is the same problem have to get the heat shelds off so we can check. Looks like a pain in the bottom!
Old Dec 19, 2014 | 11:08 AM
jacks187's Avatar
jacks187
Yea i think its the part that connects to the engine...it is going to be a pain.....
Old Dec 19, 2014 | 11:12 AM
SoBadass's Avatar
SoBadass
Oh Im out the army now. Moved to Puerto Rico when I got out!
Old Dec 20, 2014 | 11:56 AM
jacks187's Avatar
jacks187
Oh wow, das whas up........i feel ya bro!!!!! If i could do it all over i think i might be over there too lol
Old Jan 1, 2015 | 04:41 PM
Gorhad's Avatar
Gorhad
Could be the hydraulic lifters in the valve chamber opposite the valve springs. The rocker arm straddles both under the cam
Problem is when they wear they stick and lose the springyness or dont compress properly at all causing a ticking noise.
Other than that could be worn timing chain guides making a rattling noise when you put the engine under load
