taking off the emblems
Old Oct 27, 2005 | 05:11 PM
fur1ous's Avatar
fur1ous
Default taking off the emblems
Can you take off all of the emblems off of the tailgate without damaging paint. Or are they like the fords with the emblems drilled into the metal. ? Any help in this area is appreciated. Thanks Chris[:'(][X(][&:]
Old Oct 27, 2005 | 05:23 PM
Hillside's Avatar
Hillside
Default RE: taking off the emblems
The badges are not drilled. I took mine off the tailgate with some string to cut the 3M tape and used bug and tar remover with a lot of rubbing. Do a search, there are quite a few threads on this topic.
Old Oct 27, 2005 | 08:34 PM
IS_THAT_A_HEMI's Avatar
IS_THAT_A_HEMI
SIMPLE, fishing string and WD40
Old Oct 27, 2005 | 09:59 PM
HemiBuell's Avatar
HemiBuell
Probably do this the same time you polish and wax your truck.
Old Nov 4, 2005 | 12:35 PM
Mudinyeri's Avatar
Mudinyeri
The fishing line will probably work. I would have some concern - if you really like your paint job - that there might be some abrasion of the string on the paint as you saw it back and forth to slice the badge mounting tape.
Another method that we've had pretty good luck with is using a heat gun. Heat the badge just enough to soften the adhesive on the badge mounting tape and then simply peel off the badge. We use WD-40 to remove the residue.
Old Nov 4, 2005 | 01:21 PM
shoedork's Avatar
shoedork
Pepboys sell adhesive/bumpersticker remover. It did the job fine. I think Auto Zone also carries it.
Old Nov 6, 2005 | 12:57 AM
dc7derek's Avatar
dc7derek
my bro used a heat gun(blo dryer), heat it up and then pull off. then use goo gone to rub off the stickyness
Old Nov 6, 2005 | 01:25 PM
dehutzoo's Avatar
dehutzoo
If you happen to cause any minor scratches to your pain, just use some really fine sandpaper and a buffer to get them out, this is good to do anyway, becase once you debadge the vehicle, you can still see where the emblems were in certain light, the sanding and buffing will eliminate this problem.
Old Nov 6, 2005 | 06:06 PM
osteodoc08's Avatar
osteodoc08
ORIGINAL: dehutzoo
I'd use Meguair's Scratch-X well before wet sanding. Also I'd imagine paint fade will only be an issue on slightly older trucks that have spent a lot of time outdoors. Reds and Blue are typically the first to fade.
Old Nov 7, 2005 | 01:48 AM
05_black_beast's Avatar
05_black_beast
I used the 3M pinstripe removing wheel in an electric drill. Worked very well and I was done with the entire truck in under a half hour or so.
