Burning oil
Old Feb 8, 2015 | 08:10 PM
p38251's Avatar
p38251
Why run 10/30 in an engine that's designed to run 5/20. Just saying. Try a different brand. If your still having an issue, you may need to dig further.
Old Feb 9, 2015 | 06:45 PM
MikeHTally's Avatar
MikeHTally
Originally Posted by Largefarva
Mds will run fine with 10/30, done it many times.
You just don't know if your MDS is working. He could probably use 20W/50 as long as he doesn't need the MDS.
Old Feb 9, 2015 | 10:53 PM
hemiman07's Avatar
hemiman07
I have a Diablo Predator Tuner, I disabled the MDS.
Old Feb 10, 2015 | 03:17 PM
p38251's Avatar
p38251
Tolerance's of the new engines is much closer than the engines of the 70's. Running a heavier weight oil could cause flow issues. I would stick with what the manufactory recommend's JMO.
