Stalled, no start
Old Feb 8, 2015 | 08:49 PM
CalDodge's Avatar
CalDodge
Default Stalled, no start
I was sitting idle and a stop light and my truck(07 1500 Hemi) stalled. Tried to start it back up but it just turns over. First thought that it wasn't getting fuel. No codes. Fuel pump was replaced less than a year ago. I turned the key on and off and I still hear the fuel pump. Disconnected the battery for a few minutes and tried again but nothing.
I gave up and had it towed. After drop off I tried again and it fired right up but no throttle. I backed it up into the garage in idle. After that it started throwing codes and started flashings the ETC light.
P0642 - Sensor Reference Voltage 1 Circuit Low
P2111 - Electronic Throttle Control Unable To Close
P2122 - Throttle/Pedal Pos Sens F Minimum Stop Perf
P2138 - Throttle/Pedal Pos Sens/Switch F Circ Hi Input
I tried to start it again the next morning but it wouldn't start again.
Any help?! What would be the first to test?
Old Feb 9, 2015 | 07:14 PM
areinike's Avatar
areinike
I'm not a Hemi owner, but have a question, are these drive by wire? Meaning, is there no direct cable to the throttle body? I ask because I have a Benz with this issue and the codes you're seeing out of your Ram are eerily similar to the codes I'm getting out of my Benz! lol
Old Feb 9, 2015 | 07:15 PM
areinike's Avatar
areinike
Oh, with that said, I'd always start out with checking your fuses. Especially if there are multiple ECMs.
Old Feb 10, 2015 | 04:20 PM
CalDodge's Avatar
CalDodge
I think the wiring goes from the Throttle body to the APPS, or the ECM. I'm not 100% sure which one because the wires are all wrapped up.
I got it running though. I cleaned the throttle body real good and recalibrated. After a couple of ECM resets I noticed I started throwing P0335 - Crankshaft Position Sensor. I checked the sensor connection and it was loose with condensation build up from the rain. I blew it out with compressed air and reconnected it, hooked up the battery and now everything seems to be working. No codes, but it's still pretty suspect.
Old Feb 10, 2015 | 06:56 PM
p38251's Avatar
p38251
Put die electric grease on those connections that can get wet.
Old Feb 10, 2015 | 09:54 PM
areinike's Avatar
areinike
CPS would definitely do it. That was one of the issues on the Benz. Glad you got it going, great job!
Old Jan 24, 2020 | 01:58 AM
bestchance's Avatar
bestchance
areinike, yes the 2007 I'm working on is drive by wire. No cable just I electrical plug
Old Jan 24, 2020 | 06:55 PM
Alex Medeiros's Avatar
Alex Medeiros
It's almost a 5 year old thread...
