Banging bobbling sound over bumps
Old Feb 9, 2015 | 02:25 PM
jleonard's Avatar
jleonard
Default Banging bobbling sound over bumps
Been a while but im here. My 05 ram 1500 has a sound when i hit bigger road bumps. Sounds like a broken shock bobbing around under the truck. Shocks aren't broken, had it looked at twice underneath and cant find anything loose. Any ideas? Gas tank maybe? That's the only thing we didn't check. Sounds like its under or behind driver side.
Old Feb 9, 2015 | 03:06 PM
p38251's Avatar
p38251
Are the shocks OEM? Ball joints? Sway bar end links?
Old Feb 9, 2015 | 03:24 PM
If it's behind the driver, it wont be ball joints or sway bar links....try to isolate it more. Check the spring perches, axle u-bolts, exhaust pipe, etc. Gonna have to look some more, all we can do is guess.
Old Feb 9, 2015 | 06:56 PM
areinike's Avatar
areinike
I hate problems like this. lol You'd be amazed at how something "feels" from inside the truck, to what the problem actually is. Depending on what is bad/loose - can carry sound/feel throughout the truck. Sway bar end links are usually the culprit, whether they look good or not. I'd be absolutely amazed if it was the gas tank.
Old Feb 9, 2015 | 07:00 PM
areinike's Avatar
areinike
Oh yeah, jkeaton is onto something. Exhaust pipe hangers can do it, too. Didn't think about that.
Old Feb 10, 2015 | 03:59 PM
Prismatic's Avatar
Prismatic
Can of coke roll under the drivers seat?
Old Feb 10, 2015 | 09:55 PM
areinike's Avatar
areinike
lol I hate that!
Old Feb 11, 2015 | 01:45 PM
jleonard's Avatar
jleonard
LOL, funny you mention the coke can. I was so irritated at one point I took everything out from under the seats, the back seats, took the jack out and then went on a real bumpy ride. Still there.
Shocks are not OEM, two year old Monroe Reflex's all around. Need new ones but they're not broken.
Exhaust is aftermarket but the sound has existed long before that was put on.
All the balljoints and SB links were checked, no play.
Spare tire is still tight as a drum.
What wasn't checked and would make sense is the axle u-bolts. That rear suspension took a beating hauling a Work and Play toy hauler, especially through NY city. Thought I broke the damn hitch off the roads were so bad. The search continues.
