Idling Problem - Please help!
Old Feb 18, 2015 | 07:48 PM
bpearman's Avatar
bpearman
Default Idling Problem - Please help!
his is my first post to this forum. I hope somebody can help me.
2003 Ram 1500 - 5.7 Hemi
Sitting at idle it goes from 800 to 1200 rpms. When it goes up to 1200 it'll stay for about 5-10 seconds then back down to 800 for 5 seconds them back up to 1200. Does this constantly. Didn't start this until I replaced all 16 plugs/wires and cleaned throttle body and map sensor a week ago. Also sometimes just driving it'll start running real rough, no power at all and the red lightning bolt light will start flashing on the dash. I pull over to the side of the road, turn the switch off and then start truck again and it's fine. This has been going on for over a year. Somebody said it's the throttle position sensor, I bought one, said for that year and motor. Found out that the tps can't be replaced. It's built onto the side of the throttle body.
Old Feb 19, 2015 | 03:00 PM
joebaum's Avatar
joebaum
How many miles ?
Did you take throttle off so you could clock it so that cleaner/muck didn't get into internals? I would swap out throttle and disconnect battery for relearn 1st. Recheck secondary wires for proper routing. No dtc?
Old Feb 19, 2015 | 07:13 PM
bpearman's Avatar
bpearman
Right now it has 249,??? miles. I took the throttle body off to make sure I got everything clean. What is the procedure for the "relearn" when disconnecting the battery? And what is "dtc"?
Old Feb 20, 2015 | 10:28 AM
SmokinJoe02's Avatar
SmokinJoe02
Disconnect battery and touch the cables together for about 30 seconds. Upon reconnect, the truck will relearn everything within 4-5 cold starts. You'll need to start cold engine, drive until it reaches operating temp, shut off and let cool down. Do that 4-5 times.
SJ03
