Problem with my 2004 Dodge Ram 2500 SLT 5.7L Hemi, help!
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Yeah, that's 'drive by wire'. No throttle cable from pedal to throttle body.
right so what do you think could be causing this. I do have a exhaust manifold leak so unless the back pressure from there would cause that idk what would I’ve taken it to a bunch of shops and they have no clue what’s causing it.
I would be tempted to test the pedal position sensor, AND the TPS, make sure they work as they should. Analog meter is best for these. The digital fellers simply don't react fast enough.
it’s not the tps because it’s in the throttle body as one unit.
