Passenger side bench seat wont open
Old Apr 25, 2015 | 10:23 PM
mikeaceto36's Avatar
mikeaceto36
Default Passenger side bench seat wont open
I have an 06 dodge ram extended cab. I went to acces the compartment under the rear passenger side seat,and the seat will only lift a quarter of the way before it seems to be getting caught on something like a latch. Any suggestions.
Old Apr 25, 2015 | 10:42 PM
Largefarva's Avatar
Largefarva
Get a small flashlight and take a good look at the mechanism, probably sized up or binding on something.
Old Apr 26, 2015 | 10:03 AM
MikeHTally's Avatar
MikeHTally
Something jammed in the hinge, probably.
Old Apr 26, 2015 | 10:19 AM
Inspect the linkages and hinges.
Old Apr 27, 2015 | 10:42 PM
Destructo80's Avatar
Destructo80
+1 on inspect linkage and hinges. They rust and can get dirt and grime stuck in them. You can use a flat head screwdriver to move/spin the hinge mechanism on the side of the seat while you put a little force on it. Also not a bad to clean it and lube it up.
