Outside air temp display always reads 130 F Sensor?
Old Apr 28, 2015 | 07:18 PM
Joe.G's Avatar
Joe.G
Default Outside air temp display always reads 130 F Sensor?
Hi, my 04 SLT 1500 Hemi, the overhead display always reads 130 F, is there a sensor or something that I should replace? thanks
Old Apr 28, 2015 | 07:22 PM
p38251's Avatar
p38251
Yes left side under hood. In front of the condenser fan.
Old Apr 28, 2015 | 08:05 PM
Joe.G's Avatar
Joe.G
Would you happen to know a part number Having a hard time finding it on the parts break down.
Old Apr 28, 2015 | 10:29 PM
p38251's Avatar
p38251
I don't. Call your local dealer. Give them your vin. After they give you a price ask for the part number. Then you can look elsewhere cheaper.
Old Apr 29, 2015 | 06:36 PM
MikeHTally's Avatar
MikeHTally
I think mine did that for a while, then straightened up. Did you recently replace the battery?
Old May 1, 2015 | 07:19 AM
Joe.G's Avatar
Joe.G
Yes the Battery was replaced and computer has been reset. Maybe give it a little bit and see if it straightens out?
Old May 1, 2015 | 05:07 PM
MikeHTally's Avatar
MikeHTally
Worth a shot.
Old May 2, 2015 | 01:50 PM
dirtydog's Avatar
dirtydog
Moderate User
I would unplug it, let it 'cool down' and then plug it back in. When I say cool down, I merely mean the electronics inside, not because it's reading high..lol
You can read the resistance of the unit. It should raise/lower with hot/cold cycles. You can use a heat gun to perform this test. If it doesn't move, then it's cooked. No pun intended..haha
Old May 9, 2015 | 08:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Buried in the service manual somewhere it tells what what that condition means. There is also one of her condition as well but I can remember it right now.
Old May 10, 2015 | 01:41 PM
Joe.G's Avatar
Joe.G
Ok I have check things out and i do believe the sensor to be bad, I ll look up the part and get it ordered.
