Ac condenser fan not spinning
Old May 15, 2015 | 03:57 PM
Imhalfdead's Avatar
Imhalfdead
Default Ac condenser fan not spinning
I've got a 2003 dodge ram 1500 4.7 with 89k miles on it and I've noticed my ac blows warm when I'm at a stop upon doing some research I learned that it's most likely my condenser fan needing to be replaced. It's not spinning and my fuses and relay are fine. So the question is, does that mean it's for sure the fan? Or could something else be causing it not to spin? I did check the connector with a voltage reader and there's power going to it. Money is kinda tight for me right now so I wanna be as sure as possible before I buy a new one. Any insight would be appreciated thanks!
Old May 15, 2015 | 04:22 PM
p38251's Avatar
p38251
You have checked power. Can you spin the fan by hand? Does it make noise? Is it dragging, rubbing? Maybe time for a fan motor.
Old May 15, 2015 | 04:28 PM
Imhalfdead's Avatar
Imhalfdead
I can spin the fan by hand and it spins freely with very little resistance. No notice that I can hear no dragging or rubbing. And there is definitely power going to it. New motor time you think?
Old May 15, 2015 | 04:31 PM
Gone Fishin's Avatar
Gone Fishin
common problem, you've already done the diagnostic----time for a new motor. Don't run the a/c unless your out on the freeway until the motor is replaced, as the lack of air going across the condenser coil causes extremely high head pressure for the compressor and can shorten its life
Old May 15, 2015 | 04:34 PM
Imhalfdead's Avatar
Imhalfdead
Awesome thanks for the help guys! Would you recommend buying the motor? Or the whole assembly?
Old May 15, 2015 | 05:35 PM
p38251's Avatar
p38251
Motor should be fairly cheap. Alot of guys here like rock auto.
Old May 15, 2015 | 05:40 PM
Imhalfdead's Avatar
Imhalfdead
Cool Ill give them a look thank you!
Old May 16, 2015 | 01:39 PM
hemiquad4x4's Avatar
hemiquad4x4
I know you said you check the connector for power but to completely rule out any problems down stream from the connector you could run power directly to the fan motor from the battery to verify its dead. Just a thought.
Old May 16, 2015 | 01:41 PM
Imhalfdead's Avatar
Imhalfdead
How exactly would I go about doing that? I've got some experience under the hood but not a whole lot
Old May 16, 2015 | 01:48 PM
hemiquad4x4
Theres quite a few youtube videos to walk you through it but basically you need 2 wires to run from your battery, one to the power on the fan motor plug and the other to the ground/negative. If its a good motor it will run when the power is applied.
