BIG A/C Problems 2002 Dodge Ram 1500
Old May 22, 2015 | 09:25 AM
vegasfan70's Avatar
vegasfan70
Default BIG A/C Problems 2002 Dodge Ram 1500
I have several issues with my a/c. I have low air flow coming from my passenger side vents and it's much stronger out of the driver side. Also, when I try to turn on the MAX air (I am guessing the re circulation)---nothing happens. It is literally like I never touched it at all. The various speeds of the A/C do work but not the max button to recirculate. Also, it does seem that I can never control if air goes to the right area..(for example- only to lower vents, or only to main vents or both main and lower vents.) Are these all the same issue? I asked a dealership guy who told me min 1k to work on and replace all involved....I can't do that...I'm broke.
Please Help!
Old May 22, 2015 | 11:15 AM
HemiLonestar's Avatar
HemiLonestar
Sounds like the doors under the dahs have crapped on you. It's a known problem, they even have an upgrade repair kit for it. Requires pulling the dash unfortunately, that's why the labor is so much.
Old May 22, 2015 | 12:39 PM
vegasfan70's Avatar
vegasfan70
thanks for the help! Do you know if I can get the kit at Autozone or the likes? Approximate cost? Regardless, thanks for the response!
Old May 23, 2015 | 09:44 PM
mopar74's Avatar
mopar74
Search Dodge Forum for Heater Treater.
Here is the site for the best parts: http://www.heatertreater.net/magento...ram-02-08.html
Old May 24, 2015 | 01:28 AM
justang1999's Avatar
justang1999
I just fixed mine here's a post i just made https://dodgeforum.com/forum/3rd-gen...tion-door.html
