Puddle light hook up 04 1500
Old Jul 4, 2015 | 05:31 PM
PX's Avatar
PX
Default Puddle light hook up 04 1500
I've got an 04 1500 that I'd like to put some puddle lights on. My question, is where can I draw power from to have them go on when the lights go on. It's my understanding the switch it actually inside the door integrated in into the latch assembly and I cannot grab power from that. So where can I grab power from? I was thinking about running the wire up to the lights in the ceiling in the front. I want them to only come on when the doors are opened.
Old Jul 4, 2015 | 05:45 PM
HammerZ71's Avatar
HammerZ71
If 'n it were me, I'd run them their own power and use a relay wired to the door pin wire. This way they are separate and fused on their own, just using the tap into the door light wire to trigger the relay on and off.
Old Jul 4, 2015 | 05:59 PM
PX's Avatar
PX
Where do I find the door pin wire? Fuse box on the dash?
Old Jul 4, 2015 | 07:10 PM
They are attached to the door pin. Easier to remove it and tie into the wires there.
Old Jul 4, 2015 | 07:51 PM
PX's Avatar
PX
I don't see anything going to the pins.. No wires.. See the photo below.
Old Jul 4, 2015 | 07:59 PM
Find the pin. It's not there obviously.
Old Jul 4, 2015 | 08:09 PM
PX's Avatar
PX
Here's the problem. The light switch is part of the Door latch. It appears that the cable going to the door latch is just a ground.
https://dodgeforum.com/forum/3rd-gen...ht-switch.html
Old Jul 5, 2015 | 01:05 AM
KasperR34's Avatar
KasperR34
I've got Mopar M (well they used to be, now it's just a light) puddle lights in my step bars wired to the dome light wire in the A pillar.
Old Jul 5, 2015 | 08:49 AM
Yes. Door switches make and break the ground to operate.
Old Jul 19, 2015 | 05:46 PM
PX's Avatar
PX
So, I've sort of figured out what I want to draw power from, but I also want to patch into the ground on the door latch so these lights go on and off with the interior lights when the doors are opened. But I have some reservations on what wires to patch into. That being said, Here are the wires going to the door latch. Which one would be the ground I can patch into? Do I patch into the black wire? There appears to be a purple strip on that line. There are 3 others going to the plug on the door latch. See below:
I'd also like to draw the power from the power mirrors. So which wire has the constant 12V+ going thru it?
