NEED help with my dodge have 2 problems I can't figure out
Old Jul 8, 2015 | 08:34 PM
0_7_hemi's Avatar
0_7_hemi
New Member
Default NEED help with my dodge have 2 problems I can't figure out
I have a 07 dodge ram 1500 5.7l hemi 4x4 four door with 140, 000 miles...first issue is it seems almost everytime I step on the gas one single chime noise comes on no code for it did it once in awhile before now does non stop...what could it beee I have no idea.other problem is just got a code saying low oil pressure second time in last couple weeks I cleared it last timebut came on again.oil level is good oil pressure gauge is reading right little under half way mark when idling and kicks rightup to 3/4 when u step on gas so seems to have good pressure what could be causing it I don't think the two things have anything to do with each other cause they didn't start at same time plus the single chime everytime I step on throttle been doing this for last week non stop and last time oil low pressure light came on was like 2weeks ago.please help thanks
Old Jul 8, 2015 | 11:42 PM
p38251's Avatar
p38251
Bad oil pressure sending unit. Check with a direct reading gauge that oil pressure is good. When the single chime happens see if you can catch a light coming on.
Old Jul 9, 2015 | 10:11 AM
0_7_hemi's Avatar
0_7_hemi
New Member
How can I check oil pressure directly? And no light comes on at all for the single chime its weird
Old Jul 9, 2015 | 12:00 PM
p38251's Avatar
p38251
Could be a related issue. It's your call, you can double check with a gauge. However the oil pressure sending unit is a common fail item. They are a cheap replacement.
Old Jul 9, 2015 | 12:07 PM
HemiLonestar's Avatar
HemiLonestar
Do you have access to a scan tool that can read the pids? Then you'll know for sure if your sensor is AFU.
Old Jul 9, 2015 | 12:12 PM
0_7_hemi's Avatar
0_7_hemi
New Member
Ill go check my scan tool now to see if it does.How bad is it to change the sending unit.pretty simple? Thanks
Old Jul 9, 2015 | 12:30 PM
0_7_hemi's Avatar
0_7_hemi
New Member
Yes it reads pids what do I look for after I search pids?
Old Jul 9, 2015 | 01:38 PM
p38251's Avatar
p38251
I know is sounds weird. Check for a videos on u tube. There may even be one on here. You can do a search. Yes pretty simple to change.
