2007 Ram 1500 Big Horn Edition 4.7L
Old Aug 26, 2015 | 01:53 PM
StiltzM109R's Avatar
StiltzM109R
Default 2007 Ram 1500 Big Horn Edition 4.7L
I need to finally replace the suspension for the front and rear of my Ram. I tow a popup camper once in a while and haul some dirt or mulch. I also would love to get rid of the play in the steering when going over bumps or railroad tracks. Any recommendations for suspension and steering? Wouldn't mind lifting the truck a couple of inches. Not necessary though. I just want a good ride and the steering play gone. I have about 125,000 miles. Anything else I should be looking for in regards to this truck?
Old Aug 26, 2015 | 03:49 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum. Is it a 2wd or 4x4?
Old Aug 27, 2015 | 11:36 AM
StiltzM109R
It's 4x4. Thank you for the welcome!
Old Aug 27, 2015 | 11:56 AM
SmokinJoe02's Avatar
SmokinJoe02
Red face
I have 80k on my 4x2 and just did the ball joints (upper and lower), Tie rod ends, shocks, sway bar bushings, and changed 1 sway bar. Sure tightened her up!! Quiet too.
SJ03
Last edited by SmokinJoe02; Aug 27, 2015 at 01:10 PM. Reason: Chet's post reminded me of others....
Old Aug 27, 2015 | 12:25 PM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
I recently changed the front hubs/bearings, upper control arms (with upper ball joints), outer tie rod ends, sway bar bushings and end links, as well as new tires and a good alignment. I did the lower ball joints and shocks last year. It drives like a completely different truck. You just get used to how free and crappy it drives until everything is tightened back up again!
Look into Bilstein 5100 adjustable shocks for your truck if you want some cheap(ish) lift. Keep in mind that if you lift your truck, even just an inch or two, you are going to want to change your stock shocks out, anyway.
Old Aug 28, 2015 | 01:04 PM
StiltzM109R
What brand ball joints, control arms, tie rod ends, sway bar bushings, sway bar and links did you use?
Old Aug 28, 2015 | 01:21 PM
SmokinJoe02
I used MOOGS on all except the upper control arms/ball joints and the 1 sway bar. Those were the ones you get at Advance Auto with no zirks.
SJ03
Old Sep 1, 2015 | 10:15 AM
StiltzM109R
I'm going to start pricing everything out. I figure I'm going to do it all at once. Will all of this get rid of the free play in the steering wheel when going over bumps?
Old Sep 1, 2015 | 11:04 AM
SmokinJoe02
No telling, but it did on mine. Be sure to get an alignment after the work has been done. I go to brake check for my alignment, get the lifetime alignment for about $110.
SJ03
