Stalling randomly
Old Sep 13, 2015 | 08:22 PM
HammerZ71's Avatar
HammerZ71
Another freebie you can do is to ground the throttle body. It will keep rpms from fluctuating at idle and may keep it high enough not to stall. Even if it doesn't fix the issue, you'll still benefit with better throttle response...
Old Sep 18, 2015 | 10:22 PM
axeman_87's Avatar
axeman_87
ok ill get some wire to ground throttle body. See how that works. Drove around town earlier in the week and still twice i had it stall on me.. When the weather co-operates ill take the EGR out and clean it. Puzzled!
Old Sep 28, 2015 | 04:25 PM
axeman_87's Avatar
axeman_87
Update: cleaned the EGR wasn't too dirty. Not sure about bench testing it to see if still works. Grounded throttle body with 10 gauge wire to fender. Cleaned the PCV valve and I think it's the mass air sensor as well. Truck runs good still stalled on me. I tried to this time and it did. Not sure what else to look for. No codes or p codes off key. I'd like to get my hands on a Bluetooth ob2 reader to see the fuel trend. I'm just grasping at straws now.
Suggestions?
Thanks
Old Nov 4, 2015 | 01:25 PM
axeman_87's Avatar
axeman_87
Okay well still stalls, not as much. Did oil change, might have helped? Other than that I'm lost now. I got a blue tooth ob2 reader, This is off of a torque pro android app. Now is there a way to bench test an electronic EGR? Mine is only a year old.
MID:$31 TID:$95
- EGR Monitor Bank 1
Max: 227.67999% Min: 334.67999%
Test result value: 320.62%
FAIL
MID:$31 TID:$96
Test result value: 319.63998%
FAIL
Any suggestions?
Thanks
Old Nov 5, 2015 | 12:50 PM
axeman_87's Avatar
axeman_87
Does anyone have anything? I've tried everything. I don't want to bring to shop.
Old Nov 24, 2015 | 03:10 PM
locolonghorn's Avatar
locolonghorn
Default i have same issues in my 06 hemi
I have changed cam and crankshaft sensors along with the egr valve, as I'm not getting codes I'm to guess it could be the tps sensor inside the throttle body since I've cleaned it and the butterfly doesn't open so getting a new throttle body. Try cleaning yours first to see if that fixes it. If not then throttle bodies online go for about 120-450. Hope that helps
Old Jan 18, 2016 | 12:48 PM
axeman_87's Avatar
axeman_87
Update:
So changed EGR, thought it fixed it. Hasn't stalled nearly as often. I cleaned the throttle body as best I could. Looks brand new. Checked all fluids, trans was a bit low.
Now only time it stalls the its cold out., going reverse then back to drive, the engine seems to slow down then dies. Easily started up, and its all good, all day. Usually in mornings when it's -20C.
Hmm might just have to move outta the dam cold ....
Old Feb 6, 2016 | 07:41 PM
rex941's Avatar
rex941
I would check the IAC.
Old Feb 15, 2016 | 04:50 PM
axeman_87's Avatar
axeman_87
Is this idle air control part of the throttle body? Can it be cleaned or whole new throttle body?
Old Feb 29, 2016 | 04:51 PM
rex941's Avatar
rex941
connector w
ed tab center of photo
hope this helps
