Security issue 2004 Ram 3500
Old Sep 26, 2015 | 10:54 PM
trogg's Avatar
trogg
Default Security issue 2004 Ram 3500
Hi,
Hope someone can help out. 2004 Ram 3500 security light next to the speedometer cluster stays on continuously and drains the battery.I have charged the batteries,replaced alternator again,light and buzzing noise still there until I disconnect the batteries,sometimes right away or maybe an hour or two later.Is this an easy fix or major problem.
thanks for all your help on this one. Bob
Old Oct 8, 2015 | 08:00 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a possible PCM issue.
Old Oct 13, 2015 | 01:04 PM
HemiLonestar's Avatar
HemiLonestar
This happened to me when my battery was crapping out, does your truck have a SKIM key/module (security)?
Old Oct 15, 2015 | 08:53 PM
trogg's Avatar
trogg
I do not believe it has the SKIM feature. No Dodge emblem on the key and it worked fine up until recently.I will check the batteries,about a year old when they were replaced along with the alternator.I also replaced the alternator again as it was not charging thinking that had something to do with it.It still is not properly charging as it jumps around on the gauge and meter when I test.
