New alarm install = bad MPG?
Old Oct 24, 2015 | 11:41 AM
irishbandit77's Avatar
irishbandit77
Default New alarm install = bad MPG?
Hey guys after installing the CAI and superchips "performance setting" other things last month I was getting anywhere around 13.5 - 14mpg average depending on my commuting week.
Well last weekend I got a stereo and alarm installed. My commute or driving style hasn't changed but I'm now averaging 12.5mpg (full tank fill, 160miles by 1/2 mark) or so... any suggestions? I do have the Evap Code engine light thing... but that's always been there.
Is it possible they reset or messed something up with the chip setting when they disconnect the battery / installed electronics?
Old Oct 24, 2015 | 12:04 PM
What are you using to calculate mileage?
Old Oct 24, 2015 | 01:07 PM
irishbandit77
Same gas gauge marker line to needle line Left side of needle touching right ride of marker line on full and half tank mark. I don't use the overhead display thing cause it doesn't seem to be accurate... in fact its usually more generous as to the avg MPG's
Old Oct 24, 2015 | 01:53 PM
Could be any number of factors. Try calculating manually for a couple tanks. Installing an alarm system should not have done anything.
Old Oct 24, 2015 | 03:19 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed, alarm is electrical, not mechanical.
Poor fuel, heavy foot, plugs, air filter, tire pressure, head wind, bad front O2a and more all have to mileage
Old Oct 24, 2015 | 04:24 PM
irishbandit77
Tires & air filter new, plugs only have about 13k (44k miles on truck) ... been using same gas station. Hmmm..ill check things out.
thanks guys
Old Oct 24, 2015 | 04:57 PM
HammerZ71's Avatar
HammerZ71
I'm sure they disconnected battery long enough to reset the PCM. It'll relearn...
Old Oct 24, 2015 | 07:42 PM
p38251's Avatar
p38251
If it's a hemi its due plugs again.
Old Oct 25, 2015 | 07:59 AM
MikeHTally's Avatar
MikeHTally
His plugs have only 13K. Where do you get that? As for mileage, there is only one way to accurately determine the mileage.
Old Oct 25, 2015 | 10:44 AM
irishbandit77
Nope it's 4.7.reprogrammed it last night and there was an immediate difference in throttle response and power. I'll fill gas to the same line as before and re-calc the MPG's this week
