Front End Rattle
Old Oct 26, 2015 | 02:30 PM
dnorman's Avatar
dnorman
Default Front End Rattle
I have a 2004 Dodge Ram 1500 2WD and have a rattle coming from the hub area. I have replaced everything (sway bars, tie rods, rack and pinion, upper and lower control arms and ball joints). Usually a hub going bad makes a growl sound but this is a rattle when going over bumps. Have also checked hood mounts etc. Has anyone ever heard of a hub rattle? This is driving me nuts.....
Old Oct 26, 2015 | 02:36 PM
Moving this to third-gen ram section for ya.
Old Oct 26, 2015 | 04:58 PM
HammerZ71's Avatar
HammerZ71
Sure they can rattle. Put it on a lift and look for play, if there is a good bit of play you should be able to recreate the rattle...
Old Oct 27, 2015 | 12:13 PM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
By any chance did the dust cover on the brake rotor get bent a tad and might be rubbing the rotor a little?
Old Oct 28, 2015 | 07:14 AM
dnorman's Avatar
dnorman
I'll check the dust cover but I think it's prolly in good shape and tight. The sound is tinty though which makes me believe it is more of a sheet metal issue.
Old Oct 29, 2015 | 01:39 PM
p38251's Avatar
p38251
Loose caliper. Or brake pad. Loose shock
