04 Ram 1500 U Joints, are they all the same on the truck? How Many ? What brand?
Old Dec 21, 2015 | 09:57 AM
Joe.G's Avatar
Joe.G
Default 04 Ram 1500 U Joints, are they all the same on the truck? How Many ? What brand?
Hi, I am thinking about replacing my U joints though out the truck, How many are there front and rear and are they all the same part # or are there different ones used though out the truck?
What is the best brand? I was thinking of ordering Splicer, Grease able or not non grease able?
I am guessing rear D Shaft takes same front and rear, but what about front? of truck.
Any tips are replacing them?
Thanks
PS Truck is 4 WD 5.7 auto SLT Ext cab.
Old Dec 21, 2015 | 12:01 PM
p38251's Avatar
p38251
3 the front ds only has one. I used Napa precision.
Old Dec 21, 2015 | 02:17 PM
Joe.G's Avatar
Joe.G
5-1330-1X Front shaft and rear shaft grease able though cap
5-1330x non grease
5-213x grease able though cross
Spicer say's all three are the same, The part Numbers are above of what they offer.
Old Dec 21, 2015 | 03:15 PM
p38251's Avatar
p38251
Yes they are. I had the high pressure fittings in the end of the cap.
Old Dec 21, 2015 | 06:47 PM
Joe.G's Avatar
Joe.G
Is the Zerk fitting in the cap the way to go?
Old Dec 21, 2015 | 07:01 PM
p38251's Avatar
p38251
I found them easier to service. There is some controversy at strength difference. IE the one in the body of the joint makes it weaker. With it in the cap, you don't have to rotate the ds to get the grease gun in there.
Old Dec 21, 2015 | 08:31 PM
Joe.G's Avatar
Joe.G
Spicer said they are all rated the same and that there is no difference in strength.
Old Dec 22, 2015 | 07:59 PM
p38251's Avatar
p38251
That is correct. The zirk in the cap is just easier to service
Old Dec 27, 2015 | 10:27 AM
Gone Fishin's Avatar
Gone Fishin
Don't forget to paint a line down drive shafts to maintain original configuration to keep the shafts balanced
Old Apr 2, 2016 | 10:46 PM
Joe.G's Avatar
Joe.G
Well I went with Spicer 5-1330x non grease able, I replaced all 3 of them ( 2 in the Rear shaft and 1 in the front shaft. Honestly when I took the shafts out the factory Joints were still in pretty good shape. The Joints were cheap so I just replaced them.
