Hi from Houston
Old Dec 28, 2015 | 07:17 PM
lovemy2kids's Avatar
lovemy2kids
Default Hi from Houston
Please help!!! I have a 2004 dodge ram 5.7 hemi, it starts great may or may not idle and then just dies. When it does idle it will drop and you would think I was pressing gas, if I keep the gas pressed it will stay running. We have replaced the iac, throttle body, battery terminals, even had the battery tested and it was 100%. Took the positive cable off while the truck was running and if I pressed the gas it would stay on, lights would flicker as soon as I let off the gas it died. Can someone please help us? I really need this truck for my job and buying a new one is not an option at this time.
Old Dec 28, 2015 | 11:20 PM
Moving to the correct section. Is the check engine light on?
Old Dec 29, 2015 | 12:36 AM
lovemy2kids
We have received codes for misfire and the iac, replaced iac and now have codes po171 and 174 with a freeze frame code of 65. We are at a loss. We also put a vaccum pressure tester on it it tests fine. When it dies the rpm and speedometer bounce.
Old Jan 3, 2016 | 05:46 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like either a bad TPS sensor or the throttlebody is dirty and sicking in the idle position. It also acts like there is a vacuum leak somewhere causing the lean condition.
