Torque converter Capacity
Old Jan 30, 2016 | 09:59 PM
GRed's Avatar
GRed
Default Torque converter Capacity
I searched for this unless I have missed it..wasn't able to locate it.
Does anyone know that capacity of 4.7 I appreciate your help
Thank you
Gary
Old Jan 31, 2016 | 02:21 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Probably best to contact the manufacturer and ask one of their techs
Old Jan 31, 2016 | 11:49 AM
GRed's Avatar
GRed
Appreciate it, Thank you, but I think I will leave well enough alone and just do the pan maybe a couple time within a few mo's to cyc the fluid
Old Jan 31, 2016 | 02:06 PM
primem's Avatar
primem
545RFE service fill 5.2L, overhaul 14-16L
48RE service fill 3.8L, overhaul 14-16L
most t/c probably hold 1-2 liter but this volume is part of the overhaul capacity.
i'm with you, why leave 1/2 the dirty old fluid in there. Other manufacturers are stating the filter no longer has to be changed if complete fluid exchanges are done from new. Maybe fca will soon follow suit.
Old Feb 3, 2016 | 04:03 PM
dirtydog's Avatar
dirtydog
Moderate User
Fluid & Spec FAQ
Check out my Trans flush thread HERE
There's about ~12qts in TQ converter and cooler lines. Your pan only holds a small portion(5.5qts)
In above thread shows very easy way to flush all old fluid out. Takes about 1hr. Don't even have to drop the pan.
