03' 4.7 swap to 04' 5.7 Hemi
Old Feb 17, 2016 | 12:21 AM
weirze's Avatar
weirze
Default 03' 4.7 swap to 04' 5.7 Hemi
I have an 03 ram 1500 4.7l 4x4 and want to swap with a 04 5.7l Hemi. Can i use the PCM and TCM out of the 04 for my 03? and i also herd i will need a rad, fuse box, dash wiring harness, torque converter. is there anything else i should grab from the parts truck?. and has anyone else done this that can help me before i this underway.
thanks,
Old Feb 17, 2016 | 09:24 AM
HemiLonestar's Avatar
HemiLonestar
As much of the electronics that you can, including the pedal. The 04 does not have separate PCM/TCM, it's all one unit.
Old Feb 17, 2016 | 12:36 PM
big guy's Avatar
big guy
Google 2003 hemi swap lots of info out there
Here's one https://dodgeforum.com/forum/3rd-gen...003-5-7-a.html
Old Feb 18, 2016 | 09:04 AM
weirze's Avatar
weirze
So i gotta get the whole APPS sensor then, do i have to get the wires from under the dash as well? Have for do i gotta go, so far my only worry is converting from a throttle cable to fly-by wire cuz id rather do less work haha, be nice if i knew what i was doing to get everything for a fly-by tho!
Old Feb 18, 2016 | 10:30 AM
HemiLonestar
Talk to hotwireauto, that's who I'm gonna go through for my conversion. They can probably make a harness for you and with some of the parts you need to grab it'll be plug and play.
