3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I require some parts replacing a part...
I purchased a 2002 Dodge Ram 1500 SLT crew cab (5.9l) a few months back to replace my 1996 5.9l version. However, I have noticed this vehicle lacks the power and MPG as my older version.
I have been going through the engine listening for air leaks. I found one. However, I am not sure what part to get, and whether I need to go to the dealership.
The elbow hose that comes out of the throttle body and is just to the left of the MAP sensor (which is marked "34611 1/4" is cracked and in need of replacing (the imagine has been rotated so you can read the part number).
The hose is just hanging on, so I am fearful of removing it any more than it already is to inspect it fully.
Now then, the elbow comes out of the throttle body and takes a left into a hose/tube (part no. 53032054AC) which is supposedly a vacuum emission harness.
So, with this information in hand I went to the Dodge dealership and spoke to the parts guy. He had no idea what part to get, as their pictures didn't match my photo. The parts guy did suggest spending $70 to buy a long hose/tube that he couldn't guarantee would contain the elbow, nor would he agree to give my money back if it didn't.
I guess my overall question is two fold: 1) what is the part no.? and 2) do I need to even go to the dealership to replace it (i.e. it's simply 1/4 inch hose).
Any help sure would be appreciated. I have supplied the following photos.
Just get some rubber hose and replace it. No need to get the exact same OEM part. Take it off and take it with you to a parts store. If you can't find pre-bent ones, you might have to get creative with the angle, cut it a little longer so it does not crimp the hose when making the turn.
You might be able to cut off the broken part and stick the pipe back in it. If you buy hose, it doesn't necessarily need the bend. Just make it long enough so it won't kink. You could also pick up the hose from a junkyard engine.
Went to NAPA and purchased one foot of 1/4 tubing. It was the last of a roll, so it has a nice bend in it cause by a tight wrap.
So far, I have 94 cents into the repair. I plan on replacing it this weekend. I'll update you.
Thanks.
Done... and done... $1 compared to $70 and a "maybe" from the dealership. I plan on cutting it down a bit in the coming days, once it gets warm outside.
If you wanted a 90 degree bend, you could have picked up a 90 degree vacuum line adapter. Available at any hardware store or auto store. But your solution works. But really, in the scheme of things, this problem you had, or have, is like a mosquito on an elephant!
