Help!!! I am about to give up.
Old Feb 26, 2016 | 01:54 PM
mhancock3123's Avatar
mhancock3123
Default Help!!! I am about to give up.
I have a 2002 Dodge Ram with the 4.7 V8 in it. One day it ran fine. The next it won't even start. This is what I have done.
1st. I checked if I had spark. I have spark on all 8 cylinders.
2nd. I checked compression. I have compression about 120 PSI
3rd. I checked fuel. I have fuel. I don't have a pressure guage, but kitting the valve shoots a line of fuel out. (I also poured a little in the throttle body, it made no difference at all)
4th. Pulled codes and am not showing any codes. I have a snap on scanner so I checked and am getting a signal from both the crankshaft and camshaft sensor.
5th. I unbolted the exhaust just to make sure that nothing was clogged.
6th. 1st cylinder placed at TDC, looked and the damper is pointing to top dead center on the timing case. I did not removed the valve covers to check the camshaft wheel.
All it does is turn over. Doesn't even sound like it wants to start. I have searched and searched and called everyone I know and am at a loss. It sounds like it has to be out of time. I just can't prove one way or another. Is there anything else I am missing.
Old Feb 26, 2016 | 03:44 PM
p38251's Avatar
p38251
Do you keep cam and crank position sensors signals when cranking? Should be able to see that on your snapon scanner.
Old Feb 26, 2016 | 04:09 PM
mhancock3123
I can and they have signal.
Old Feb 26, 2016 | 06:58 PM
p38251's Avatar
p38251
It almost sounds like you're loosing spark during crank.
Old Mar 1, 2016 | 09:07 AM
superdak05's Avatar
superdak05
check your fuses, there maybe a blow one keeping truck from starting, or your security system locked you out, also if you have a second key, try using that one
Old Mar 1, 2016 | 09:11 AM
superdak05's Avatar
superdak05
also, remove your gas cap when starting, you may have vapor lock
Old Mar 3, 2016 | 09:43 PM
Black Jack's Avatar
Black Jack
Are the battery terminals good/ tightened? Might have wrong cable clamps for the posts or perhaps just a grounding issue somewhere.
Old Jul 31, 2016 | 10:24 AM
04FloridaHemi's Avatar
04FloridaHemi
Any resolution to this problem, my 04 5.7 is doing the same thing. I have one more symptom... fuel gauge reads empty but has a full tank.
Old Jul 31, 2016 | 10:24 PM
Friar Tuck's Avatar
Friar Tuck
Question 04 FloridaHemi
What is yours doing/not doing?
Any trouble codes?
What have you checked/eliminated?
Did your fuel gauge just stop working?
Old Jul 31, 2016 | 10:45 PM
Friar Tuck's Avatar
Friar Tuck
Lightbulb Fuel Pump Sending Unit
I don't have wiring diagram for '04.
In the '03, the sending unit is connected to the PCM on Connector 1 pin 4 on a BLACK/LIGHT BLUE wire, and Connector 3 pin 26 on a LIGHT BLUE/BLACK wire.
