LED tail light bulbs
I hope it’ll work out as I planned. The biggest issue will be to change the single reverse light to dual function socket. Judging your pictures it looks like the sockets have been ‘melted’ in to place, so that may require some drilling and creating a new fixture with some screws.
The big challenges I now have is where to find the connection plates and the white/yellow led light without switchback function.
I hope you’ll be able to dig up what wire has what function, so it makes it easier for me.
Did you have to separate the negative connections in the socket themselves in order to create the non-CK connections?
No, see the pictures I posted at the beginning of this thread... you have to cut the silver bars in the gray "box" to "re-route" the grounds. I did not make any modifications to the sockets themselves.
Just wanted to pass on my recent Ram mod. I have always wanted to put LED tail light bulbs in my Ram. About a year after I bought the truck (around 2006) I installed a set of LED blinker (amber) lights in the front using the required load resistors and they have worked out very well. My intention was to install some LED lights in the tail lights shortly thereafter and have finally got around to it in 2016... 10 years later!!!
Part of my procrastination was the discovery that the rear tail light bulbs had to be "CK" type... do an internet search on it if you don't know what that means. Additionally, I reasoned that I would have to have three load resistors per side to make it all work. I did not want to buy whole replacement LED tail lights as I wanted that stock "factory" look with the advantages and "bling" of LED. So, I got off my duff recently and made it happen. My solution was to purchase two stock tail light circuit boards for my truck and re-wire them to accept standard type LED bulbs so that I could simply plug in my stock tail light plug into the re-wired circuit boards and have everything work correctly. That way, if I ever decided to go back to stock, it could be done easily, in a few minutes and without having any cut wires.
Well, as I mentioned, I finally got it done and it turned out GREAT! I am very pleased with the light output and operation of the new bulbs and the fact that you just don't see LED bulbs in these 3rd gen Rams... making it a little unique.
Here are a few pics of the project...
The circuit board re-wire picture does not include the additional wiring for the resistors.
On the picture of the back of the truck, the left side are the LEDs... the right is stock. Hard to tell much difference in the picture, but they look a lot better in person... especially the white back up bulbs.
The two pictures of the bulbs are what I installed.
This project was a lot of work for the benefit, but I like it and I'm pleased with the results. I am planning on now doing LEDs in the 3rd brake light, cargo light and license plate lights so that all exterior lights are LED (except headlights).
If anyone is thinking about doing the same thing, just let me know and I will be glad to answer any questions.
