Brakes:Semi metallic vs. Ceramic
Old Apr 8, 2016 | 09:45 PM
  #31
Joe.G's Avatar
Joe.G
Just the opposite for me, Cross drilled and Slotted always seemed to last longer.
Old Apr 9, 2016 | 10:00 AM
  #32
Gary-L's Avatar
Gary-L
Veteran: Navy
I'm surprised as well the representative stated installation location did not matter. If anything, that person is not qualified to be providing performance materials advice.
The rotors I installed on my Mazda were labeled LF/LR, RF/RR. My cousin has run slotted rotors on performance cars for years and stated they are directional and must be installed in the proper location lest damage to the rotor or surrounding area occur due to part failure.
Old Apr 10, 2016 | 06:42 AM
  #33
Joe.G's Avatar
Joe.G
If you notice most companies slotted/drilled rotors want you to install them so they look backwards when on vehicle, Power stop who I happen to run on my truck has you put them on so they look like they are going the opposite.
https://www.google.com/search?q=Dril...uetDlV-u67M%3A
Most I see go like this above.
My power stop go like the ones on the BMW I think it is, first pic bottom row.
https://www.google.com/search?q=Dril...UP5-XNz5qHM%3A
Old Apr 11, 2016 | 12:44 PM
  #34
RamedHemi's Avatar
RamedHemi
The ones I got are not cross drilled. They are dimpled and slotted which helps disperse heat. Having ceramics for towing is may be worse because you will be really heating those rotors up. Ceramics are a harder compound and produce much more friction and heat then semi which leads to warping. This is why I went this semi metallic plus what factory calls for. I Just learned all this recently. I plow in the winter and on the brakes a lot during storms. This is my first set of dimpled/slotted ill see how they hold up. If they warp they will be replacing under there lifetime warranty
