Gas Gauge Takes Forever to Change after Fill-up
Old Mar 22, 2016 | 11:47 AM
03GrayLiftedHemi's Avatar
03GrayLiftedHemi
Default Gas Gauge Takes Forever to Change after Fill-up
Hi All,
Newbie to the forum.
I have an 03 Dodge Ram 2500 Hemi. Love the thing.
Whenever I go to fill up, after doing so I usually turn the key to the next position. When I do that, the fuel gauge doesn't change at all. (It stays showing empty)
Then when I start the truck it starts to go up...but very slowly. Like really slowly.
Could this be an indicator of anything?
Thanks in advance!
Old Mar 22, 2016 | 12:09 PM
Mithril's Avatar
Mithril
Originally Posted by 03GrayLiftedHemi
Hi All,
Thanks in advance!
Has anything changed recently? My 04 takes some time to climb to full, it's all part of the dampening circuits to keep the fuel gauge from bouncing as fuel sloshes around in the tank. Mine can take 5 minutes or better to register full. If yours is the same it sounds normal to me.
-Bob
Old Mar 22, 2016 | 12:18 PM
03GrayLiftedHemi
Hi Bob,
Thanks for the reply. It's a recent purchase so I just wanted to make sure it was ok.
Thanks for the quick answer!
Mike
Old Mar 22, 2016 | 01:52 PM
SmokinJoe02's Avatar
SmokinJoe02
Welcome to the forum. Mine has done it once since I gained ownership about 18 months ago. Just keep an eye on it. Try not to let the fuel level get past 1/4 to empty. Keep us posted.
SJ03
Old Mar 24, 2016 | 07:16 PM
MikeHTally's Avatar
MikeHTally
Strange. Mine jumps right to full (then I hear a satisfied burp).
Old Mar 24, 2016 | 07:42 PM
p38251's Avatar
p38251
Mine did as well. Could be the float arm is hanging on a wire. Or the electrical portion is worn out. It's a potentiometers setup.
Old Mar 24, 2016 | 11:23 PM
Will_V2Lab's Avatar
Will_V2Lab
My 04 does this too. I've often wondered if maybe the fuel pump was going out (still pumps fine though).
Old Mar 25, 2016 | 11:44 AM
03GrayLiftedHemi
That's what I was worried about too. I guess I'll just keep watching it and look for any other signs of a WP going out.
Thanks for the reply!
Old Mar 25, 2016 | 06:53 PM
p38251's Avatar
p38251
Fuel pump and fuel gauge are two separate Parts.
Old Apr 6, 2016 | 04:41 PM
bleachcola's Avatar
bleachcola
i changed my fuel pump last year, the whole bucket and everything, and ever since that i have the same problem,
probably made a mistake or pinched something,
takes 5 mins or 2 or 3 starts after refueling for the gas guage to show full, after that it works fine
