Engine dont start at first ignition.
Hi there,
Be smart with me cause i am living in Belgium and this is my first post.
So i got a start problem of my hemi. The problem dont occur all the time.
Sometimes, when i try to run my engine, he dont start. I ear a click but i need to insist several times to be started. (4 or 5). Someone told me that it can be the starter. It is not the starter cause i have changed it today. Spare plig have been changed, relay have been checked.
Other one told me that it can be the solenoid into the transmission. The solenoid dont see the neutral position, so the engine cannot start properly. I have also a strange display on my board. all the selector have little square on it. Parking, neutral, reverse, drive, have a square displayed on it. Maybe somebody have already seen that?
I am not mechanical expert and expert in english.
Please help
Please help
I will and let you know the result. Thanks for your support
Ed
It's late and I'm going to bed here, but I recall a thread not too terribly long ago about someone having squares around every position of the gear indicator. Give a search for it and see if something comes up. Try different keywords and see if you get a good hit.
I have clean up the wire from the box of fuses. It seems that it run at first start, but as i said, the problem dont occur all the time. I will check it on several days. Regards Ed
Trending Topics
I cleaned the ground on the engine, it seems that it resolve my problem. My engine start at first ignition, and i dont have anymore squares on all gears. I need to see on next days, if it is really fixed cause as i said, the problem dont occur all the time. Thanks to the man who gives me this advises.
