throttle body help
Old Apr 2, 2016 | 07:32 PM
tigerpaw40's Avatar
tigerpaw40
Default throttle body help
I did something today ill never do again I don't care how dirty it is
I cleaned my throttle body put it back together and now it goes down to 1000 rpms then the lighting bolt comes on for just a second and it revs up to 1500 how do I fix this thanks for your help
05 dodge ram hemi
Last edited by Chet Ubetcha; Apr 5, 2016 at 01:18 AM. Reason: Hit "edit" instead of "quote". Put it back to the way OP's post originally was.
Old Apr 2, 2016 | 09:25 PM
HammerZ71's Avatar
HammerZ71
Could be one of a number of things. First of all, what did you clean it with? A lot of chemicals will foul the hell out of sensors.
It's fly by wire, so unless you physically broke something or screwed up a sensor odds are it's electrical, like a broken wire or loose connection...
Old Apr 3, 2016 | 12:07 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
Are you sure you plugged everything back in?
What did it idle at before you cleaned the throttle body? You should be idling about 500 rpm lower than you are indicating before the jump.
Old Apr 3, 2016 | 04:04 PM
MikeHTally's Avatar
MikeHTally
Yep, you have to keep the motor up so no cleaner gets in it. Also, non-chlorinated brake cleaner only.
Old Apr 4, 2016 | 10:49 AM
superdak05's Avatar
superdak05
as long as you removed the tb for cleaning you did nothing wrong, once you disconnect the sensors from the tb, the computer needs to relearn. start and stop truck a couple times to see if that helps, if not just feather the gas when you come to a stop sign or light, soon it will regain its signal and be ok, I have the same issues everytime I clean mine or disconnect the battery for service
Old Apr 4, 2016 | 12:32 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Use this stuff:
Throttle bodies have special coatings that other cleaners can remove.
Old Apr 4, 2016 | 09:46 PM
tigerpaw40's Avatar
tigerpaw40
thanks for all your help ill give it a week and see if it goes back to normal
its my buddies truck and I thought I screwed it all up why cant they leave stuff alone and stick with just a cable opening it up
that's why when people tell me to get a new truck and stop driving my 94 Dakota I say no way!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 5, 2016 | 01:17 AM
Chet Ubetcha
05 dodge ram hemi
So, yours or your buddy's?
Everybody makes mistakes of sorts, or at least thinks the do when things aren't exactly as they were before the "fix", and then second guesses if they should have ever messed with it in the first place. Just one of those things you learn from for the next time you do it. Don't let it dissuade you from trying again the next time maintenance is due. Could be something as simple as the computer needing to relearn itself, or it could be just using the wrong chemicals. Sometimes an "oops" costs you a little bit of money, but you learn from it.
Old Apr 6, 2016 | 07:16 AM
MikeHTally's Avatar
MikeHTally
Originally Posted by Gary-L
Use this stuff:
NO!!!! Brake cleaner only! Dodge released a TSB on this years ago.
